I/O file
I have a bunch of strings that I would like to write to the same file. I
want each string to be on a different line. Up to now, all the strings
are on the same line. What could I do
Thanks for your assistance
Alexandre Berchemin-Sirven
Sent via Deja.com http://www.deja.com/
Before you buy.
(3,974 Views)
When you put the strings together (either in concatinate strings, or in your
loop... etc.) just append an "End of Line" character to the end of the
string. To get this, go to the string menu, and you'll see six pink boxes
that represent different strings. The fifth one is the End of Line, which
is what you want. Concatinate your string with the EOL character and you're
all set!
HTH,
Rick
rick@csciences.com
Chesapeake Sciences Corp.
1127B Benfield Blvd Millersville, MD 21108
Tel: (410) 923-1300 x3430 Fax: (410) 923-2669
(3,974 Views)
Thanks for our assistance
Before you buy.
(3,972 Views)
In article <7tce6g$i3u$1@nnrp1.deja.com>,
> Before you buy.
Alexandre,
You should send at the end of the
line a caracter " \r\n "
Before you buy.
(3,974 Views)
Alexandre
You should send at the end of the line a caracter
" \r\n "
> Before you buy.
Before you buy.
(3,973 Views)
thanks for your assistance
Before you buy.
(3,972 Views)
