I Need Help! Analyzing Frequency Components of Accelerometer Vibration
Hummer1 wrote:
Here is a little background on sampling theory.
The faster you sample, the higher the resolution you get in the frequency domain when you do the FFT on the data.
http://en.wikipedia.org/wiki/Sampling_(signal_processing)
Hope this helps
Hummer1
I'm going through the link. Thanks for taking the time to post something which could help me.
Sincerely,
Jason
Message 11 of 16
(1,696 Views)
Hi Alterrock,
The write to spreadsheet takes either a 1D or 2D array.  If your extract tone function is givein you a cluster, you need to do a unbundle by name to extract the array inside the cluster.
Yik
Message 12 of 16
(1,689 Views)
Dear  Preston Johnson,
Can't we simply use "Basic DC/RMS" VI to find and remove DC value of the Accelerometer signal insted of using Median?
Is Finding Median a better option for removing DC from accelerometers?
Please clarify.
Message Edited by ssingh1 on 25-02-2010 12:58 PM
Message 13 of 16
(1,662 Views)
Hello Preston,
I am using NI hardware : cDaq9174, module 9233 and an accelerometer (IRD make mil521)having sensitivity 100mv/g.
In the vi we are integrating the signal to get vel. & further disp.We calibrated the setup by taking the reading on motor pulley set up rotating at @1250 rpm
All three parameters Accln.,vel.,disp.were correct.When we increased the rpm the readings were wrong.
As operating freq. 0f 9233 module is @ 21kHz, can we select 20kHz sampling freq?
Pl. guide .
regards,
Sam
Message 14 of 16
(1,334 Views)
Sam,
Thank you for using NI forums! You can find the valid sampling rates for the 9233 here. As you can see, you can sample at 25 kS/s or 16.6667 kS/s, but not at exactly 20 kS/s. Hope that helps!
Katie
Katie Collette
Message 15 of 16
(1,319 Views)
Hello Katie,
Thank You very much for your suggestion. Now pl. guide about no. of samples to read using 9233. At present sampling rate is 25Ks/s and I am reading 10000 samples . Will it be O.K.
Message 16 of 16
(1,298 Views)
