HyperTrend parameter to manipulate this ActiveX
Hi guys
i'm working now with the HyperTrend, i try to manipulate the parameters of the ActiveX under HTMML code, but it doesn't allow to change the defaults parameters.
can anybody say me, if i can change the paramters or not? or i have to change a specific paramter to eable the another parameters, or simple NI protect his HyperTrend for anybody can't change the paramters under HTML or another platform (for example VisualC#).
Thanks for the help
best regards
Marcelo
(2,910 Views)
Marcelo,
You should be able to use and set the methods and properties of the NI Hypertrend using the ActiveX API.  I have tried setting various properies such as ShowLegend and it seems to work ok.  There are some properties such as StackedPlots which don't seem to work, probably because the method or property was not implemented.  Unfortunately there isn't much documentation for the NI Hypertrend so using the ActiveX API requires a bit of trial and error.
Doug M
For those unfamiliar with NBC's The Office, my icon is NOT a picture of me 🙂
(2,896 Views)
Thanks Doug for your Response
First. You spoke about an ActiveX API, where can I activate the API, because, when I work under HTML, I can´t see the API, please cann you tell me the procedure to Activate the API unter HTML.
Second. I tried to manipulate the methods and properties under HTML of the HyperTrend, but the HypreTrend don’t show any change. I sent to you the HTML code, maybe can you test that:
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=windows-1252">
<title>Trend LV Historical Data</title>
</head>
<body bgcolor="#D2D2D2">
<p>
<object id="NIHyperTrend1" classid="clsid:ADA6E9EE-06F1-11D3-A51C-006008CA119A" width="678" height="676">
 <param name="ShowLegend" value="True">
 <param name="ISplotting" value="False">
</object>
</p>
</body>
</html>
Marcelo
(2,864 Views)
