Hydraulic control system for aircraft
I have been given a college project for a simple aircraft control system. Given below is the task.
Using LabVIEW, simulate the operation of four actuators of four elevons using 3000
psi hydraulic pressure from aircraft hydraulic system. Also bring back the actuators
to neutral position once hydraulic power id removed.
• Create a user-friendly dashboard in LabVIEW’s front panel to display real-time data
and analysis results. This can include graphs, gauges, and indicators that alert
users to potential issues.
Please direct me to similar examples so that I can get an idea on how to start with the project as I have zero knowledge about LabVIEW.
Regards
(467 Views)
Hi Shady,
In this case you should use the Training resources as offered at the top of the LabVIEW board!
There's nothing "simple" when "aircraft" and "3000psi" are involved!
(434 Views)
