Hydraulic Test Bench Software
Looking for software like this for a Hydraulic test bench. Have Labjack
Data acquisition software. Interested if someone has wrote similar software
or is willing to help me write something.
Message 1 of 29
(7,510 Views)
Hi there, welcome to the forums. While there are many experts here offering their help for free, if you need a full application created it is best to look at the NI Alliance Partners and hire someone. If you want to make this application yourself, you will find help quickly if you post a well-defined question. If you are just looking for general tips on LabVIEW programming, there are some links at the top of the forums to get you started:
Message 2 of 29
(7,483 Views)
Do you think someone could help me design what is in the picture I sent.?
Message 3 of 29
(7,480 Views)
The picture is just a front panel, and it would be quite easy to make something that looks like that. The actual code, i.e. the block diagram, cannot be seen from the picture. But in general, yes, LabVIEW is a very capable programming environment and it excels at data acquisition and graphical user interfaces, which are what you are after.
Message 4 of 29
(7,476 Views)
What information is needed to help me get this designed?
Message 5 of 29
(7,446 Views)
Hi tchirpich,
It would help to know what your specific requirements are. Do you have any experience with LabVIEW?
The forums are generally used for specific programming/hardware questions, or for helping identify issues with your code. Gregoryj hit the nail on the head here. The image you posted was just the User Interface; there isn't any information of how it was coded. If you could find the actual source code and posted some specific questions about it, I'm sure others would be able to help.
If you are looking to build an application from the ground up, you can check out the NI Alliance Partners (also as Gregoryj had mentioned). Alliance Partners are highly skilled with LabVIEW and NI hardware, and are experts in the eyes of NI. They would be willing to help you spec out and develop software for your system, provided you have an idea of what you want to do.
Let us know if you have any questions!
Best,
BrandonN
Message 6 of 29
(7,429 Views)
Hi, hope everything is going well, I've been looking for something similar to a develop what I'm finishing right now and I would like to ask you if you already find what are you looking for.
My software has a human machine interface to perform a dynamic hydraulic test of a linear actuator by controling a PLC or controller related, taking samples of pressure, temeprature and shaft travel position.
If you are intereseted I can send you a trial version.
Please keep on touch, I'll be glad to have news from you.
KR.
Message 7 of 29
(6,839 Views)
Here is the picture, but I have no coding to interface this to our bench, can anyone help me write the coding?
Message 8 of 29
(6,821 Views)
Here is what I have, can anyone help me write the code for this???
Message 9 of 29
(6,817 Views)
Can you send me a screen capture? I just work over linux distribution and can't open .ctl files.
Just in case, I can develop an app for you but outside off LabView, one can run stand alone and cross platform.
Thanks for your time.
Message 10 of 29
(6,812 Views)
