How
I have made a simple VI to show you one possible solution to your problem (see attached, LabVIEW 7.0). 🙂
Let me know if this is clear.
Message 21 of 123
(4,439 Views)
Altenbach:
Can you save that in v6.1 for me?
Message 22 of 123
(4,436 Views)
@AnalogKid2DigitalMan wrote:
Altenbach:
It seems that some of the grid features used by the VI can't be backsaved. You could try rebuilding it from scratch, though.
___________________
Try to take over the world!
Message 23 of 123
(4,429 Views)
Analog,
I have downconverted it to 6.1 but I cannot test because I no longer have 6.1 installed. There is a chance that it uses certain features that were not avaliable in 6.1, so you might have a broken VI. Should be easy to fix, though. See of it works.
I did not get any error messages while converting, so it is probably OK.
If you don't understand some features of the code, use execution highlighting. 😄
Message 24 of 123
(4,423 Views)
Christian,
     Could you do that with a "Save with Options: Development Distribution", when I load it keeps looking for the Transmorgrify function.
     P.M.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 25 of 123
(4,421 Views)
@LV_Pro wrote:
... when I load it keeps looking for the Transmorgrify function.
Sorry, that one is proprietary. However, you should be able to construct something equivalent by using this manual. 🙂
Message Edited by altenbach on 10-27-2005 10:50 AM
Message 26 of 123
(4,407 Views)
Some additional help can be found in the dedicated HOW magazine...
Chilly Charly    (aka CC)
Message 27 of 123
(4,375 Views)
Should we let people know how Labview actually works?
That there are thousands of tiny programmers converting the vi's to CVI code in the back-ground...
Message 28 of 123
(4,358 Views)
Three hoorays for the tiny programmers, HOORAY Smiley Very Happy, HOORAY Smiley Very Happy, HOORAY Smiley Very Happy.
Hihihi Smiley Wink.
Message 29 of 123
(4,344 Views)
Okay, I tried some of your sample codes and I turned into a couch.  Now what??
Amateur programmer for over 10 years!
Message 30 of 123
(4,341 Views)
