How to write to a multicolumn listbox
I am using a listbox that extracts information from 2 different colums. The information in these column is converted to a number using a string to number function. I want to multiply the information in each cell of a column with it's adjacent cell and put the result into an unused column in the listbox.
ie column 1, row 1 = 200, column 2, row 1 = 3 and i want to multiply these 2 cells together and put the result in column 3 row 1 and basically fill down from there depending on whether there is information present in cells.
Can someone show me how to do this? Any help would be most appreciated.
(3,066 Views)
hello,
see the attached files for help.
Software developer
www.mcm-electronics.com
PORTUGAL
(3,030 Views)
This example performs...
Multiplication of row data and add the result to a new column of the same row.
PS: No of original data columns will be automatically detected.
Hope this helps!
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(3,024 Views)
