How to write this string as a regular expression format?
The string format is YYWWPXXXXM
YY-YEAR
WW-WEEK
P-PRODUCT
XXXX-BATCH NUM
M-MANUFACTURER
Examples are 2123A3456G, 2111G3463H, or 2019C4928P.
Since this is a mix of letters and numbers, how would I write this as a regular expression?
(2,103 Views)
YY-YEAR
WW-WEEK
P-PRODUCT
XXXX-BATCH NUM
M-MANUFACTURER
You're trying to pick this out of a larger string?
Bill
CLD
(Mid-Level minion.)
(2,099 Views)
If that's all you're receiving, it's easier just to chop that up by offset.
Bill
CLD
(Mid-Level minion.)
(2,097 Views)
With the Scan From String VI, you can use this format string, as long as there are no letters that will appear in the year, week or batch num fields.
%2d%2d%1s%4d%1s
aputman
(2,087 Views)
If you're trying to parse each subfield, use aputman's Scan From String advice. If you're trying to ID your string in a big list of other strings, use this regex:
[0-9]{2}[0-9]{2}[a-zA-Z][0-9]{4}[a-zA-Z]
(Tip, use https://regex101.com/ to check)
(2,075 Views)
