11-27-2006 05:17 PM
11-27-2006 05:37 PM
11-27-2006 05:45 PM
11-27-2006 05:51 PM
11-28-2006 10:10 AM
11-28-2006 10:33 AM
In versions lower than 8.20 there was only one vi for the write to spreadsheet string and it only accepted numbers and in 8.20 it is polymorphic meaning that it will accept both. There is instructions on the block diagram on how to modify the write to spreadsheet vi to use strings. Modify this VI and save it as a new name so that you do not corrupt the original. Replace my write to spreadsheet string with the one that you modified and replace my write to spreadsheet with your original write to spreadsheet then it will work. Sorry about that I forgot about the new version being polymorphic.
Which version of LabVIEW are you using?
11-30-2006 10:55 AM
11-30-2006 11:24 AM
