10-07-2016 04:24 PM
I want to write a static clock to HSDIO, when running the code, the clock will run until I stop the code. Also, I want to create a step function, at the beginning, the signal is '0', and there is a transition after some time, the signal will be always '1' until I stop the code. Thank you.
10-10-2016
03:03 PM
- last edited on
02-19-2026
03:02 PM
by
Content Cleaner
Have you considered doing this with scripting? This is a good resource for getting started:
I'm thinking you could do this with two waveforms. Something like this:
wfmA:
Clk 0 1
Step 0 0
wfmB:
Clk 0 1
Step 1 1
script ClkandStep
repeat until scripttrigger0
generate wfmA
end repeat
repeat forever wfmB
end script
Just keep in mind that Clk would output at half the rate that you clock the output waveform at.
10-10-2016 04:37 PM
Thank you for your help.
