How to write single point samples to DAQmx task after executing multiple sample point write?
I'm currently hitting a wall here with the following problem: I have a DAQmx I/O where on the same channels single point writes are to be mixed with multiple point writes.
To give you the gist of the idea: I have a laser with a power modulation input. While idle the power is controlled through a power meter in closed loop through a LabVIEW PID; this is done using single point analog value writes. At certain conditions however a short modulation burst is to be emitted. For that a multiple point sample write is used. After that burst it's back to regular PID control.
Doing single sample writes in a loop, followed by a single multisample write for the burst works fine. However after the multisample write burst the task can no longer be used for writing single samples, giving a buffer size mismatch error.
What am I doing wrong?
(2,896 Views)
Attach your VI so we can see what you are doing.
(2,875 Views)
