How to write data to excel in specified format?
Hello.
I am using activex to write data array to excel worksheet. Data format is string. Is it possible to specify data format (text, number, time...) in cells using activex?
(5,025 Views)
BPS,
Yes you can.   This snippet uses a mix of the Report Generation toolkit and ActiveX to format a column of timestamps.  Just modify the 'format string' to meet your needs.
(5,005 Views)
Can you attach the VI file please??...am new to labView and i dont recognise a few blocks
(4,834 Views)
The VI is attached. It's a 'Snippet' (look it up in the help). And, each VI has its name shown. Use the search button on the functions palette.
(4,818 Views)
