How to write data to a text file
New to Labview here, with no programming background, so this will probably seem like a no-brainer to most of you. I need to continuously 2 channels of pressure data over time (two pressure transducers). I'd like to save this data, along with a time stamp so I can plot in excel pressure vs. time data. When I run my VI, it only saves to text file the most recent iteration. I added the feedback node because I found it on a past example for a similar VI, but I'm not really sure I understand what it does. I've attached my VI here.
Any thoughts or suggestions?
(4,760 Views)
1. There is no need for that feedback node.  Just use the control directly.
2. There is an input to the Write To Delimited File VI for "Append to File".  Set that value to TRUE.  When it is FALSE (the default), then file is overwritten each time the VI is called.
(4,744 Views)
Great. That seems to have taken care of it. Thanks!
(4,726 Views)
Wow, an Instrument Assistant!  I usually recommend that LabVIEW Beginners avoid the Dreaded DAQ Assistant and Dynamic Data Wires, but in your case, I'm wondering why you didn't start there, especially as I think it has a data logging option that takes you right to Excel or a .CSV file.  [I still would recommend that you "stretch your mind" and learn some more LabVIEW by looking up (on the Web) "Learn 10 Functions in NI-DAQmx" and avoiding the DAQ Assistant, but that's another story].
(4,686 Views)
Bob,
Thanks for your reply. I was interfacing non NI components, thus, from my understanding, DAQmx would not work. The components I am using are made from MKS instruments. I couldn't find any drivers, so that was the only way I could figure out how to do it. It was actually easy, as the MKS manual provided the proper syntax for communication.
I will soon need to control Bronkhorst pressure/flow controllers from Labview. If you have an article about instrument control for beginners, please point me in that direction.
Thanks again.
(4,665 Views)
From the Bronkhorst Web Site -- Manual FLOW-BUS LabVIEW Driver.  So they do know about LabVIEW, so maybe it can interface with DAQmx ...
(4,659 Views)
Not likely.  DAQmx is NI's driver suite for NI equipment.  Bronkhorst likely made a DLL driver and possibly a LabVIEW wrapper for that DLL.
(4,643 Views)
