How to write back to the CMD Line
I'm working on a small little .exe that other individuals can use for their automation (Python... other langue than LabVIEW).  Does a quick simple task and that's it.  I was reading here how to pass cmd line arguments into my application.  But how do I pass back out a result?  Like, for this instance, I'm getting a file, I'm changing the file type and possibly the name, and I wish to send back out to the user what the new path/name is.  How does one do that?
Message 1 of 14
(1,211 Views)
I don't think it is possible to build a CLI application with LabVIEW.
Santhosh
Soliton Technologies
Message 2 of 14
(1,198 Views)
Oh?  So we can feed it arguments, let it do its thing, and then that's it?  Make sure it quits and move on?
Message 3 of 14
(1,189 Views)
Accepted by topic author LuminaryKnight
Yes, LabVIEW-built applications can only take arguments as input and do not return user data to the caller/command line.
https://forums.ni.com/t5/LabVIEW/return-Argument-to-CMD/td-p/3729229
Santhosh
Message 4 of 14
(1,181 Views)
Well that stinks.
So new question.  Is there a way to get it to not open the UI?  My app doesn't have a while loop, I've put "Quit LabVIEW" and I made sure "Show Front Panel when Called" is not checked.  But it still opens for a blip of a second.  Would love for it to not do that.
Message 5 of 14
(1,175 Views)
Message 6 of 14
(1,173 Views)
I misunderstood. Nevermind
Message 7 of 14
(1,168 Views)
Set the VI window run time position to Minimized also.
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 14
(1,161 Views)
That'll work.  Thank you
Message 9 of 14
(1,151 Views)
Scratch that, it's not working. Any thoughts on what I'm doing wrong?
Message 10 of 14
(1,088 Views)
