How to write a single Value to an excel spreadsheet
   I am using an excel spreadsheet as if it were an external code module. It does lots of calculations, all I have to do is write a sigle value to it, let it calculate what it needs to then read single a value back from it.
I already have a structure that can read back an array, but could someone help me with a peice of code that could write a single value?
(Maybe to read a single value too would be handy)
Also, I have the new LabVIEW 2009, so if any one fancy's dropping a bit of code here as a .PNG, it would be nice to see if that new feature works! 🙂
Many thanks, Alec
(3,842 Views)
A little searching of the forums could find that answer.
Here is one link.  http://forums.ni.com/ni/board/message?board.id=170&message.id=129120&query.id=1876179#M129120
(3,840 Views)
yes, but thats not actually an answer. I have been trawling the forums but am new to ActiveX, this is the first time I have ever used it so could just do with a prod in the right direction
(3,833 Views)
Accepted by topic author alecjcook
Try this. There are 2 methos item(get ) and item (put)  for reading and writting value respectively to a cell in excel .
Best of luck
Message Edited by gak on 08-10-2009 12:00 PM
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(3,820 Views)
