How to write OCR character file
Hi all I am using NI-VISION toolkit, for LCD segment investigation, I am trying to read LCD display with OCR functions, which need a character set file. How to write OCR file that is format in which we have to write. Regards Devender
(3,261 Views)
In the start menu under  Nation Instruments\Vision on the is a link to a "OCR Training" application which can make Character Set Files.
If you want to do create a file from with in labview, You'll want to look through OCR functions in the function pallete Vision And Motion\Machine Vision\OCR.
(3,257 Views)
I suggest you use Vission Assistant to create your Character Set File. It is a lot easier than trying to do it in code in LabVIEW. Then just reference the path where you saved this file in the OCR Read Function in LabVIEW.
(3,245 Views)
