How to write 3d graph to powepoint presentation
Hi
I am plotting a 3d graph in labview and then exporting it as an object. This object is inserted in powerpoint file by selecting the cw3dgraph option from toolbars. This process is working manually. But the problem is I have lots of 3-d graph data and I have to manually export and import each single graph to make a presentation. Is there a way to automate this process so that there is a VI which opens a new power point file and writes all 3dgraphs on different slides. If someone could help me in gettting started with a simple code I will highly appreciate it.
Ankit
(2,742 Views)
When I need to automate keystrokes in windows, I use macroexpress.
http://www.macroexpress.com/
(2,723 Views)
