How to work with BarTender software from LV ?
  • I hope you have succeeded in your quest. Could you please guide me through the process? Currently,  I am trying to print one barcode in two formats, interfacing two printers to a PC, using bartender & Labview
    thanks in advance
Message 11 of 13
(720 Views)
You can have 2 label files where you mention the Barcode data with a variable linked to any database or text file. You can update the database or text file from the Labview with the content to be printed.
The label files has to be selected with the name of the printers installed and saved.
When you trigger the print command through activex for the file it will fetch the varaible from the specified location and print in the printer you specified.
But you have to trigger both the files seperately.
I think you go the point.
Please reply in case of any doubt or further clarification.
Message 12 of 13
(677 Views)
Dear Johnny
Thank you for your response,
I would try the same and will update you about the progress,
Thank you once again
Message 13 of 13
(653 Views)
