How to work with ActiveX Container on tab control?
I am using LabVIEW 2020. I place an ActiveX container on the FP. I place an Adobe Acrobat Reader object in that container. I am using software from https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kGDwSAM&l=en-US. Everything works fine. I select a .PDF file and the file gets displayed. Also, the LoadFile boolean out from IAcroAXDocShim turns ON.
Then I drag the ActiveX container to one of the pages of a tab control. I select a .PDF file; the file does not get displayed and the LoadFile boolean out from IAcroAXDocShim does not turn ON.
Then I drag the ActiveX container back out of the tab control. I select a .PDF file; the file does not get displayed and the LoadFile boolean out from IAcroAXDocShim does not turn ON.
Does ActiveX not play well with tab control?
(1,781 Views)
Accepted by topic author Hamilton_Woods
And now, the solution!
I was creating a VI to demonstrate the problem, but the VI worked. Then I did the same thing in my target application, and it worked there as well.
Don't you wish you knew what I did? For the sake of other unsuspecting pioneers in the future (including me), I am posting what I did.
As previously, I created an ActiveX container on the FP. I placed an Adobe Acrobat Reader object in that container. Then I created a copy of the ActiveX container by selecting it, holding down CTL while dragging the ActiveX container onto the target tab control page. I referenced the copy of the ActiveX container that is on the tab control page. That solved the problem. I am attaching the test VI that shows the PDF viewer in action on the FP and on a tab control page.
As has been pointed out previously, loading a PDF file is a bit slow, but I can work with that.
(1,779 Views)
