How to use write to spreadsheet VI to export data to excel?
Hi Neil,
you should always reference the message you're talking about…
When you ask for PAnands snippet: use a filename extension of "CSV". Excel will happily read the file created by LabVIEW!
Message 21 of 27
(3,604 Views)
@Neil_Helsel wrote:
How did you get that to save as an .xlsx file because when I attempt to open the file excel says it can't read it?
If you are using a comma as the delimiter, then make sure you are saving your file as a *.csv.  I using the tab, then *.txt.  Excel will read these two formats if you set them up properly.
Message 22 of 27
(3,602 Views)
hey. DFGray.
i am having problem with logging rate . i am getting to many values in 1 second can u explain further how to avoid it.
i am attaching the screen shot for ur refference.
i want to log data only IFF  the data which i am willing to store has been changed.
Message 23 of 27
(2,789 Views)
Hi Begine,
Then you should program your VI according to your requirements!
What's your problem?
Message 24 of 27
(2,786 Views)
how to skip that multiple entries in excel file?
Message 25 of 27
(2,783 Views)
in the vi attached. i want to log current cycle , time date, and some few parameter will be there. i  am getting so many numbers in a while. how can i modify this?
Message 26 of 27
(2,780 Views)
Hi Begine,
Again: follow your requirements!
Only save the new data when they different to previous ones…
On your VI:
- Why do you use While loops when you know the number of iterations? Use FOR loops!
- Using BytesAtPort is most of the time wrong. When you messages don't use a TermChar their length should be known…
- Why do you need to split wires when they transport the very same value?
- You might think about using a proper state machine instead of all those loops-inside case structure-inside loops…
Message 27 of 27
(2,776 Views)
