How to use write to spreadsheet VI to export data to excel?
Hi Vanessa,
that's ReplaceArraySubset.
You don't need it. Use a BuildArray instead, no need for shift register, array constant and ReplaceArraySubset…
Message 11 of 27
(6,457 Views)
Hi Gerald,
I am referring to the array block that is connected to an empty string and a comma. Is it replace array subset as well?
Vanessa
Message 12 of 27
(6,453 Views)
Accepted by topic author VanessaWen
Hi Vanessa,
that is ArrayToSpreadsheetString, also to be found in the array palette…
Message 13 of 27
(6,451 Views)
Gerald,
Thanks a lot! 😄
Vanessa
Message 14 of 27
(6,447 Views)
Hi Anand,
I have tried to use your code exactly. It works. However, I would like to add in header for each column. Any idea how should I start? Thanks!
Vanessa
Message 15 of 27
(6,445 Views)
Check the attached VI. You don't need Insert into array when you are using Replace Array subset.
(I am not able to attach VI, thats why I have attached zip file.
Message 16 of 27
(6,434 Views)
Hi Anand,
The zipfile does not contain any vi. Perhaps you can share to me the basic idea to implement the column header?  Thanks!
Vanessa
Message 17 of 27
(6,405 Views)
Check the attached snippet. This writes the header before starting the data acquisition.
Note: The data can be 1D or 2D array. If you find the data is not in proper column/row try to use Transpose array (While using the 2D array).
Message 18 of 27
(6,396 Views)
HI Anand,
Great! Thank you so much for the explanation. I really appreciate it. Thank again. Smiley Very Happy
Vanessa
Message 19 of 27
(6,390 Views)
How did you get that to save as an .xlsx file because when I attempt to open the file excel says it can't read it?
Message 20 of 27
(6,150 Views)
