How to use waveform chart or waveform graph as a control
Hi All,
I need to use waveform graph or waveform chart as a control, can anyoone help me regarding this. I tried a lot, but unable to generate waveform.
Pramod M G
(2,944 Views)
How you are planning to generate waveform using Chart or Graph?. Why do you want to make that as a control?
(2,940 Views)
Instead of using a numeric control to provide data as 5V or 10V, to send data as a waveform. Can we do without using FGEN ?
(2,937 Views)
If you want to generate a waveform you have to use FGEN and it is the simple method otherwise you can manually perform mathematical calculation for the waveform and do that. But you cannot generate a waveform by simply using a chart as a control.
(2,935 Views)
