How to use tree control
I'm tring to read the Symbol property node of a tree control. And I got this error message:
Error 1135 occurred at Property Node (arg 1) in TreeControl.vi
Possible reason(s):
LabVIEW: The tree control's active item is not valid for this property.
Am I doing something wrong? Do I Have to set anything?
Is there a tutorial, a video?
Nitrof
(5,954 Views)
I haven't played with the symbols in the tree control, but it sounds like from the error message that the item currently selected in the control can't have a symbol associated with it--like perhaps if nothing is selected? Can you post your code? That would help in troubleshooting.
In terms of your other questions, there isn't a tutorial on the thing, or a video. The interface is not particularly intuitive either. I have been playing with the thing fairly extensively and might be able to provide some pointers. What are you trying to do?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(5,954 Views)
I have worked quite a bit w/ the symbols. You must set the "Active Item Tag" before getting or setting the symbol. NOTE: The currently selected item is not the active item, you must set it.
I think the attached VI should shed some light on your trouble
-Norm Kirchner
Engineering Specialists
NormK@engspec.com
(5,954 Views)
Hi Mike,
Here is the sample code. Like you just mention. The interface is not very intuitive. I'm not even sure of what is a symbol. I'm beginning with tree controls and I'm trying to see what I can do with it. What I want to do is have a selection of signal and dynamically assign theses signal to controls that are in the Sub Panel on the right side of my application. One thing that I would have liked to do is. Have the possibility to drag signal from the tree control and & drop them onto the desired control. I also want to associate a property to theses signals and keep trace if a signal as already been assigned to a control. If you have any clues that could help. I would appreciate. where to begin to use the tree control.
N
itrof
(5,953 Views)
NJKirchner : If I could rate this message a "10" I would. This has been a real showstopper for me for weeks now!
It's a shame the string "1135" didn't show up when I did my search. I had to be referred here by an NI rep who'd read it in the past.
Many thanks!
(5,639 Views)
