How to use the sound card to generate any waveforms that I want??
I want to use the PC's sound card to generate any types of waveform, and the frequency or amplitude can be adjusted. I search the Labview's examples and find no suitable one.
How to do it?
Thanks in advance!
Labivew 7.0
(2,738 Views)
Have you looked at the example called Continuous Sound Output? It uses the Basic Function Generator to create a waveform. All you have to do is add a control to select the waveform type and change the amplitude constant to a control.
(2,726 Views)
