How to use the data acquired by DAQ and substitute the data to a calculation in LabVIEW and then output the result through another line of the DAQ?
Dear ALL,
If I got data continuously from AI0 of DAQ, now I hope to write a calculation with the data in LabVIEW with Numeric function, and then I can get results from the calculation through the output of DAQ.
Is it possible? how to deal with it?
Thanks!
Best.
Jason
Message 1 of 8
(3,684 Views)
Hi Jason,
Is it possible?
Yes.
Read your analog input.
Calculate the needed output value.
Output that value using an analog output.
Do you have a specific problem?
Message 2 of 8
(3,680 Views)
Thanks for the rapid reply!
I got 4 lines of voltage data through AI0~AI3 from the DAC. Next, I hope:
1.calculate the data with a mathematical formula inside LabVIEW and output the result through AI of DAQ or
2.use the data acquired by AI0~AI3 as the input of a new VI created by multisim and then output the result from the new VI.
Could you please show me how to deal with the above problems? It would be better if there is a snippet or example.
Thanks again! I am grateful!
Best,
Jason
Message 3 of 8
(3,676 Views)
Accepted by topic author leo321
Hi Jason,
Write down your math formula on a sheet of paper.
Then implement this formula in LabVIEW.
Btw. with an AI you can only read analog data from your DAQ device. To output data you need to use an AO channel!
Again: do the beginner courses offered for free to learn LabVIEW.
Here you are asking how to create subVIs with inputs and outputs…
Message 4 of 8
(3,673 Views)
Hi GerdW,
Thanks for your reply!
But how can I use the acquired analog data as a parameter in the formula implemented in labview and just get to know the final result?
Thanks again!
Best,
Jason
Message 5 of 8
(3,668 Views)
Hi Jason,
how do you use any other value as parameter of your formula?
Which formula?
Any more specific information?
Simplified example:
Message 6 of 8
(3,648 Views)
Thanks.
But it's not what I mean. It's OK. I find the answer.
Thanks again!
Best,
Jason
Message 7 of 8
(3,642 Views)
Hi Jason,
Then you should write what you "mean".
And you should attach VIs explaining your problem…
Message 8 of 8
(3,637 Views)
