How to use multiple DAQ Assistant with digital and analog signal input simultaneously for logging
1- I would specify sample to read in Daqmx read function? If so, would that cause a problem with continuous aquisition? Or the loop in general?
2-Elapse time could be less, is that using a lot of buffer or is it susceptible of making error?
3-I could use index, I will probably if the basic function of this VI works
+ I might make another vi to read the 2 tdms file after, or maybe i could put the reading in same one after loop is stopped?
Message 11 of 11
(496 Views)
