How to use matlab function with labview?
I just want to use some matlab functions like floor(),ones()... in my labview code, who can tell me how to do it?
 I want to only install MCR in my PC, so MATLAB script node can not work because it need matlab installed.
(3,026 Views)
Accepted by topic author tanggio
floor() exists on the standard labview pallet already and the ones() function would be fairly simple to reproduce. If you only need a few basic functions repost asking for direction on recreating those specific methods. However, you're right - there is not a direct way to use compiled matlab code in labview without full matlab and the math script nodes. If you're really desparate to reuse some some exisiting IP there are C++ alternatives that implement many of the same methods and syntax as matlab (http://arma.sourceforge.net/faq.html). I'm fairly sure there are other tools that attempt to translate matlab code into pure c functions, both of which can be called via a DLL from within labview: https://forums.ni.com/t5/Developer-Center-Resources/Calling-C-C-DLLs-from-LabVIEW/ta-p/3522488
Alternatively, here is an all NI linear algebra solution: https://www.ni.com/en/support/downloads/tools-network/download.labview-multicore-analysis-and-sparse...
(3,017 Views)
Thanks,I am clear.
(2,996 Views)
