How to use labview to control USB6251 to output digital waveforms of different frequencies?
Whenever I use the API to output a digital waveform, the output of my USB6251 is always a 550Hz square wave, no matter how I change the frequency of the waveform in the program.
(1,179 Views)
Accepted by topic author okkkkkk
Hi ok,
Then you clearly made something wrong!
As you didn't attach your VI you need to debug on your own…
(Keep in mind: we cannot edit/run/debug images with LabVIEW, so attach real code. Not all of us use the latest LabVIEW version, so please attach a downconverted version of your VI if neccessary.)
(1,151 Views)
Hi
Thanks for your reply.
I have solved my problem.
okkkkk
(1,117 Views)
