How to use buffer with LabVIEW v5.0.
Hi all,
I'm using LabVIEW 5.0 (quite old version) . Now I want to do this task :
    1. Write 100 patterns (8 bits) to buffer.
    2. When the task writing finish, read the first 50 patterns in this buffer.
But I don't know, does LabVIEW 5.0 support to do this example ?
Could you give me an example for it ?
Ha Le
(2,630 Views)
What kind of buffer are you talking about? It sounds like all you want to do is create a 100 element array. Use a for loop, the initialize array function and then Replace Array Subset inside a loop with a shift register, a build array and shift register inside a while loop, etc. After the array has been built, you use the Index Array function to read it. Maybe you could provide some more details on exactly what you want.
(2,619 Views)
