How to use a com server develpped in python
I am trying to use a Com server, developped with python to communicate with an equipment.
The server is working fine if  called from VBScript ex:
Set device = CreateObject("My_server")
msg = device.DetectTactic(NomTACTIC,portCom).
I have tried through the ActiveX AutomationOPen, but my Com server doesn't appear in the List.
How can I correctly register this Server (I have only done a regsvr32 Path/Myserver.dll command)
Any help will be welcome.
Best regards
Marc Baulin
(2,683 Views)
To select an ActiveX, you have to place an refunum automation on your front-panel and then right click >> Select ActiveX class >> Browse. Your server should appear in the list.
On the follow link, you will find how manually Register Type Libraries, ActiveX Controls, and ActiveX Servers :
Hope its help.
Isabelle
Ingénieur d'applications
National Instruments France
(2,673 Views)
