How to use Third Party Licensing and Activation Toolkit ?
Hello Application Engineers,
I would like to add an activation code or an installation key to my installer for deployment. I found a link to the Third Party Licensing and Activation Toolkit,  addressing the issue, Third-Party Licensing and Activation Toolkit Download - NI
I followed the instruction, Installed JKI VI Package Manager (VIPM) before installing the Third Party Licensing and Activation Toolkit. However, I could not find where to start the Third Party Licensing and Activation Toolkit, and could not figure out how to use it.
I also found another page
 LabVIEW 2014 Third Party Licensing & Activation Toolkit Readme - National Instruments (ni.com)
it says that an example can be found
Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the Third Party Licensing & Activation Toolkit are located in the labview\examples\addonlicensing directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
However, I do not see the addonlicensing directory at all.
Could someone provide me an example VI in 2015 version so I can copy and paste/edit into my VI ?
Thanks',
Gu
(1,799 Views)
I had the same problem and found the solution there : https://www.vipm.io/package/ni_lib_tplat/
Now Third Party Licensing & Activation by NI is distributed on VIPM.
The thing is documentation is not update and can be misleading.
I think NI or JKI need to update there documentation on it. There is a lot of information spread out all over the place and it's not an ease ...
You can also found the topic "Publishing a library on VIPM ?" on lavag.org
https://lavag.org/topic/22694-publishing-a-library-on-vipm/#comment-144265
Youssef Menjour
Graiphic
www.Graiphic.io
y.menjour@graiphic.io
LabVIEW architect passionate about robotics and deep learning.
Follow us on LinkedIn
linkedin.com/company/graiphic
Follow us on YouTube
youtube.com/@graiphic
(1,605 Views)
