Another piece of data that may be relevant. A tab control has a property called "Pages". This is an array of references to it's pages. If you select one of these refs and wire that into a property node, you can get an array of references to all the controls on that page (including the clusters). You'll have to identify the control you want. You can either go through the entire array and match it by type\name, or if you want - the array is sorted by tabbing order. You can access a control like that if you trust the tabbing order won't change.
___________________
Try to take over the world!
