How to use LabView by combining with C++?
(2,716 Views)
A little more specific question please. LabVIEW has the C Interface Node (CIN) and can call dll's. You can create a dll from LabVIEW that is callable from C++ or you can control LabVIEW via ActiveX.
(2,716 Views)
Bruc,
There are some good tutorials and application notes you may want to read, they will teach you how to combine C++ with LabVIEW.
In order to get there follow this direct link or the path explained below:
Using External Code in LabVIEW
Path: zone.ni.com >> Resource Library (in your left) >> LabVIEW >> Development System >> Communicating with External Applications >> Using External Code
Nestor Sanchez
Nestor
(2,716 Views)
