How to use Delphi from LabVIEW?
How can one connect LabVIEW with Delphi ?
The idea is to use Delphi to develop numerical-intensive calculations and call the code from LabVIEW. Is there a way? Would an other solution be better?
(3,474 Views)
The easiest way is to create a DLL with Delphi, which contains the
needed functions. So you are able to call them not only from LabVIEW but
any other language.
Henrik Skupin
(3,474 Views)
The first option is to build your functions into a DLL and call them from LV.
I'm not sure if your version of Delphi can produce ActiveX components. If the answer is positive, you can call their methods from LV too.
If is not to complicated to translate your routines in C code, you can integrate/call them in LV as CINs (Code Interface Nodes). If the code is not too big, you may consider formula node in LV.
The last option is an executable built in Delphi. It will be complicated to transfer data to/from, but this depends on your inputs/outputs related to those calculations.
Regarding performance, I think the order is 1-CIN,2-DLL and 3-
ActiveX.
Hope this helps
(3,474 Views)
