How to use Biomedical signal Waveform to control different appliances
I acquired an Electrooculogram (EOG) signal which varies depending on our eyes movement. Now, the signal's waveform has an amplified voltage amplitude in volts on Y-axis and the acquisition time in seconds on x-axis. The aim of my project is that: whenever any value of the voltage (Y value) is <5 = turn on the first LED, 6-10 = turn on the second LED, 11-15 = turn on both, Default=turn of both. Here, I want to use the Y value (I care even for a single value to be in a range) as a case selector. please, help me.
Keneni, from India
thank you!
(2,611 Views)
it is not clear what the minimum and the maximum values should be. An attachment of your work (VI) is always useful to provide you assistance.
Here are some hints:
Use a while loop
Use some comparison tools inside of the while loop...
And if you still need some hints, please attach your VI or a screenshot.
Good Luck.
Greetings and Regards,
James
(2,496 Views)
