How to use 6601/6602 for PCI as a DIO card
I want to configure the whole 32 lines of 6601 as my application's digital input or output,but I don't know how to do it.Can you help me?By the way,do your company have the DIO card that has 32 lines.
(3,073 Views)
For having access to the 32 digital lines of your Counter/Timer board, all you have to do is call three main VI's:
DIO Port Config (where you indicate port width = 32)
DIO Port Read
DIO Port Write
Here's an example that shows how to do this:
Accessing the Digital Lines of the 660x Devices
Talking about the Digital I/O boards, I would recommend to take a look at the PCI 6533 or PCI 6534 at Products and Services
Good luck with your application!
(3,073 Views)
doing this in windows is easy enough, but what about us linux users? 😃
i'm trying to use DDK to write to the DIO lines 9-32 . any example code out there?
(3,073 Views)
