How to update the payload of CAN frame during transmission?
I already has that event case. But I can not update it to the original frame.
Message 11 of 15
(1,017 Views)
Do you want to transmit a frame consisting of rolling counter or checksum? See this.1.PNG2.PNG
You can use XNET Create Session.vi to convert signals interface to frame session, and then use XNET Convert.vi turn them back to a frame after changing your signal values. Finally you can transmit your signals in frame pattern.
Message 12 of 15
(1,010 Views)
May I get your VI? Thank you
Message 13 of 15
(1,007 Views)
Thank to your support. I also can understand my problem now. Thank you
Message 14 of 15
(975 Views)
Hello, can you explain how you solved the problem?
Message 15 of 15
(377 Views)
