How to update numeric indicator with digital input
hvazquez wrote:
I have one last question before closing this discussion. I attempted to add a secondary switch, however, both signals (LEDs) and counter behave in the exact same way.
How can I have the counters be independant from each other? I also tried to add a png to this message, however, for some reason I am not able to, so I attached the code.
Sounds like this is what you are looking for.  The numeric array is keeping all of the counts.  For display purposes, you could just use the single array or use Index Array to pull out the individual counts you care about.
Message 21 of 25
(1,533 Views)
Hi crossrulz, thanks for the feedback.
I tried to write the code like the one you uploaded the photo of, however, the connections to both of the arrays are shown like broken wires, I'm I missing something?
Message 22 of 25
(1,505 Views)
First, it's a SNIPPET, not a photo. A snippet can be dragged to a block diagram. Second, of course you missed something bit since you did not attach what you did, it's impossible to say where you went wrong.
Message 23 of 25
(1,495 Views)
I apologize, I forgot to attach it. Also, thanks for the clarification.
Message 24 of 25
(1,485 Views)
Accepted by topic author hvazquez
The SW1 and SW2 indicators are booleans, not array of boolean like you created.  Likewise for the numeric indicators for the rising edge counts.
(If you turn on context help and hover over the broken wires, it will actually tell you why the wires are broken.  Smiley Wink)
Message 25 of 25
(1,454 Views)
