How to turn a string into boolean
When I get the response "ok", I want a true, and for any other response/no response I want a false.
(2,810 Views)
mcduff
(2,794 Views)
= "ok".
I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
Learn LabVIEW
Example_VI_BD
(2,793 Views)
You already got solutions, but it would really help if you explain what kind of problem you are trying to solve with all this.
(Guessing from the question that you are not very familiar with LabVIEW, so you might be barking up the wrong tree. Similar to my comment here, explain the problem, not force certain tools ;))
What are you going to do with the boolean? If it is used for code decisions only, you might just wire the string directly to a case structure and make one case "OK" (case insensitive) and the other the default. No boolean needed. 😉
(2,777 Views)
