How to trigger off of a clock signal?
Hello all,
I am working with the BNC-2110 and  just trying to turn both a digital and analog port off using the value of a clock signal? Does anyone have any advice?
(3,230 Views)
Can you explain a bit more your application to have a better idea on how to help you.
(3,193 Views)
The BNC-2110 is just a dumb terminal block and does not have digital or analog ports or a clock signal. You need to use an actual DAQ device and you need to explain exactly what you mean by turn off.
(3,187 Views)
Ideally, I am going to have a single clock signal that I can modify the frequency and duty cycle. From that clock signal I want to run two ports off of it. For example I want the port to output a pulse of a specified width every time the clock signal goes high.
(3,150 Views)
