How to time a case structure?
Hi irsa,
whenever I press "Reset" the "Time has Elapsed" goes to TRUE for exactly 3s:
Can you verify this?
This would be step 1: verifying the correct working of the ElapsedTime part to generate a signal being TRUE for the time of your measurement.
In step 2 you need to check if the data saving works as expected. Did you talk with Jawad on this topic?
Message 11 of 17
(2,348 Views)
With your guidance we are almost near to solve this issue. I verified both the steps for the code attached to this post. Whenever i press "record" it saves for next "6" sec. The only issue now is that alongwith saving those 6 sec, it always save first 5.4 sec data when we press "run" button. I just want to get rid of these almost 5.4 sec data now.
Message 12 of 17
(2,343 Views)
Hi irsa,
This is "by design"…
ElapsedTime will start with "time is not elapsed" after each start of the VI.
You need to program a logic to avoid saving data in the first 6s after run!
Spoiler
Hint:
run time := current time - start time
IF run time < 6s THEN
  don't save
ELSE
  use ElapsedTime condition
ENDIF
Message 13 of 17
(2,339 Views)
I have created a logic in code but dont know how to give current time and start time as input to case structure used as if else condition.And secondly how to place this condition/case structure in the code. Is it positioned at correct place , i mean outside the loop?The code is attached....
Message 14 of 17
(2,330 Views)
Can you please convert the logic (given in your last post) to LV code. I am trying but couldnot get it properly.
Message 15 of 17
(2,329 Views)
Accepted by topic author irsa
Hi irsa,
You have a huge problem with THINK DATAFLOW!
Why do you put code, which needs to be executed in your loop, AFTER the loop?
Why do you use controls instead of reading system time?
Simple solution:
Message 16 of 17
(2,324 Views)
Its done perfectly 🙂 Thank you so much
Message 17 of 17
(2,298 Views)
