How to tell which VIs are running?
When I stop my Main.vi, all the subVIs should be stopped. But when I go to close my project, it says some VIs are still running? How can I tell which VIs are running? Where can I get a list of these?
Message 1 of 19
(4,838 Views)
If you turn on the light bulb on the block diagram you should see a green arrow on a vi that is still running.
Tim
GHSP
Message 2 of 19
(4,837 Views)
How do you start your subvi's ?
How do you stop your main vi ? ( I hope not by the Abort button)
Message 3 of 19
(4,823 Views)
But my Main.vi has stopped. So nothing in Main.vi should highlight, because all subVIs should have stopped before Main.vi stopped.
I am not sure that any subVIs are running, but LabVIEW 2010 says they are when I go to close the Project. It may be confused.
Message 4 of 19
(4,821 Views)
I start my subVI's by using them in the block diagram of Main.vi or one of its subVI's.
I stop my Main.vi by using the Stop button to set a global Terminate Boolean variable, which causes all of the subVIs to Stop, which eventually lets Main.vi to end execution. This seems to work OK.
If Main.vi can not stop execution until all of its internal subVIs have stopped, why does LabVIEW 2010 report that some VIs are running (when I go to Close the Project) after Main.vi has stopped?
How do I get a list of any running VIs so that I can track this down?
Message 5 of 19
(4,809 Views)
Can you attach your code here so that we can help figure out your problem without guessing.
Tim
GHSP
Message 6 of 19
(4,809 Views)
Normally, VI which is displayed is running.
If you want VI to work at the same time, open files I upload
Message 7 of 19
(4,806 Views)
I don't understand what you are saying.
Message 8 of 19
(4,792 Views)
I thought you want VI work at the same time..
If it's not, just my misunderstanding...
Normally displayed VI is runnign and other are stopped.
But I'm not sure so if you upload the VIs, people can see it
Message 9 of 19
(4,790 Views)
can you post your code? That would make it a lot easier to help.
Tim
GHSP
Message 10 of 19
(4,788 Views)
