How to take outside input to Control and Simulation Loop?
Currently I'm using SIT to take the output from SIMULINK and put it in LabVIEW. I wanted to use the output to be the input of some function in the Control and Simulation Loop. Anyone know how I could connect the output from the SIT to the Control and Simulation Loop?
I tried using global variable but the simulation in Control and Simulation Loop seems like it is not synchronize with the input connected.
(2,555 Views)
Hi Tebu
  I don't fully understand what are you trying to do. Can you send a screenshot of your code? That might explain things
Javi
(2,532 Views)
