How to synchronize two devices to start different tasks at the same time?
Hi all,
I am currently using a Zaber linear stage for towing models and a NI USB-6289 DAQ board to acquire data from sensors mounted on the model. I use a simple VI with a DAQ assistantto acquire data from the USB-6289. I installed an external LabView driver provided by Zaber and I am using one of their example VIs to send a series of commands to the linar stage to perform motions. These are two separate VIs at the moment. I have attached snapshots of the VIs.
I want to synchronize the start of the motion with the starting time of data acquisition from the DAQ board so that I can co-ordinate the signals at each timestamp with the position of the model at that time. The data acquisition from the DAQ board starts when I run the "DAQ.vi". For the linear stage, I input the parameters in the front panel and motion starts as soon as the requests are sent to the device. I have highlighted this part in the block diagram.
What is the best way I can synzhronize these two separate tasks in different VIs? Should I integrate the two VIs and then try do this? I am pretty new to LabView so it would be great if any of you can help me with this.
Thanks a lot!
(3,322 Views)
I am attaching the vi files as well. I believe the Zaber vi will only work when the driver is installed. I am attaching the driver here as well. It can also be found in the Help menu >> Find Instrument Drivers >> Search for the keyword Zaber.
Thanks!
(3,308 Views)
You can use many structures from the "synchronization" pallete menu. I used the notifiers in the example. Keep in mind that notifiers do not queue up, once the wait on notification function misses the notification, it wont know it happened.
(3,307 Views)
Dear s.vignesh,
I am also controlling a linear stage and a DAQ with loadcell values continously, Here is my block diagram maybe this will helpful. It is not finished yet. I have been busy with this since 2 mounths. Trying to learn Labview by the time. They can be in the same vi. Putting them at the same while loop may be the solution to  synchronize.
Kind regards.
(3,305 Views)
