How to synchronisse the input signal with the time scale at waveform graph?
I am using  LabView 8.6 to display the analogue signal (input) in waveform graph. May I know how to set the scale at x-axis such that the the time scale at x-axis is synchronous with the input signal? Is there any function in LabView that I can directly obtain the data about revolution per minute (rpm) from sensor?
Message 1 of 1
(2,314 Views)
