How to swap two columns in excel using labview?
Hello all..
  Is it possible to swap or cut-copy-paste a column of data in a excel file to another column of the same file using labview??
Message 1 of 8
(4,250 Views)
Hi Sumithra,
Are you using ActiveX to control Excel? If so there are 2 ways:
1. Cut Data A, then paste it into temporary location. Cut Data B, then paste it into Location A. Cut Data A at the temporary location into Location B.
- All you need to know is how to cut and paste data set from/to your specified location. Do you know how to do it?
2. Read Data A and Data B into LabVIEW, overwrite Location A by Data B and overwrite Location B by Data A.
- All you need to know is how to Read and Write data from/to LabVIEW.
Before making any assumption, please explain how you are accessing Excel using LabVIEW.
TailOfGon
Certified LabVIEW Architect 2013
Message 2 of 8
(4,241 Views)
hi..
Thanks,i guess i have found the solution.By the by im using activex control.
Message 3 of 8
(4,237 Views)
hai
  I got the solution by some other logic.Kindly let me know how how to cut -copy .i dont know how to do that.
Message 4 of 8
(4,228 Views)
@Sumithra Nagappan wrote:
hai
What is your solution?
Show us your VI.
Message 5 of 8
(4,222 Views)
hope this helps....
Message 6 of 8
(4,207 Views)
There is 2 ways to look at this.
The first one is to do as TailOfGon suggested, cut and paste the column using a temporary range to rearrange their order.
The second one is to get the table values from Excel using the Range Value(get) property, swap the columns in LabVIEW using something similar to Apok (althought a better approach will use the in place element structure) and put back the values in Excel using the Range Value(put) property.
I tend to prefer the second way since it requires less activeX manipulation (only one range is used) and allow the user to perform operations on the data.
Ben64
Message 7 of 8
(4,174 Views)
this VI has more "user" control...Smiley Wink
Message 8 of 8
(4,144 Views)
