How to store samplerate in tdm format with dll?
I'm writing a tdm export using the tdm library for generating the tdm header. Binary data (i16) is already in a seperate file and defining the (block-)channels in tdm file works fine. But how or where do I describe time information (sampleclock) for that measurement. All channels have same samplerate.
Christian
(3,509 Views)
Hello Christian,
please post your development system and the version so that i am able to help you in this case.
If you generate the tdm file in lavbiew please take a look at the example finder and search for the "tdm".
Use the Write TDM File.vi to generate a tdm file.
You are able to define a new input in the write data express vi (like sample clock).
Kind regards,
Elmar
(3,481 Views)
Hi Elmar,
thanks for your answer. I do not work with labview, so maybe I'm wrong in this group. I develop with Delphi and/or Visual Studio. To generate the TDM header for already stored binary data I use the NI TDM DLL (niTDMHW1_0.dll). Everything works fine, my channel definitions are interpreted correct and data is shown correct (e.g. in DIadem). But as there is only channeldata (=measurement values) in the binary file, I've to add a "timebase" or a definition for sampleclock etc.
In the examples for NI TDM DLL I found how to add timebase for DIadem with tdmwCreateImplicitChannels, is that the common way to setup the time relation with measurement data?
Thanks in advance
Cheers
Christian
(3,473 Views)
Hello Christian,
i talked with the developer in aachen about your request.
And yes this is the common way in this case to produce such a header.
Kind regards,
Elmar
(3,445 Views)
