How to store interpolated values from a while loop into and array and then create a graph
I have created an interface where excel data is extracted and the data is interpolated within a while loop. I then output that interpolated data. I now want to store the interpolated data into an array to plot a XY graph.
How do I do this?
I have attached a section of the interface below
Message 1 of 23
(1,756 Views)
There is nothing attached.
Message 2 of 23
(1,736 Views)
should be attached now
Message 3 of 23
(1,707 Views)
A picture of a tiny truncated section of code is not helpful at all!
Please attach your VI (or a simplified version of it). I assume there is probably an outer loop and you have arrays of x values somewhere. Are the x-values for the upper and lower interpolation the same or different?
Maybe this can give you some ideas....
Message 4 of 23
(1,690 Views)
I have attached a simple version below, the previous method you had stated did not seem to work.
What I am trying to do is plot a graph of each combination of throttle position and Thrust. Also I want it to plot multiple plots on a single graph as later versions of the interface have changing environmental conditions.
Thank you
Message 5 of 23
(1,658 Views)
Hi AJ,
you still didn't provide any code!
(We cannot edit/debug/run images in LabVIEW. Please attach real VI files!)
Why do you need to read the sam Excel file in a loop?
Why do you need 4 IndexArray nodes when one would be enough? (They are resizable!)
Message 6 of 23
(1,648 Views)
This the first time I have used LabVIEW and I don't know how everything works. I just constructed this VI from watching videos and reading posts. I have been constantly making changes to my VI to make them better. If you have any suggestions that make my VI better please let me know, it will be much appreciated?
I have attached my VI below
Message 7 of 23
(1,645 Views)
Hi AJ,
many of us still don't use the latest LabVIEW versions, so could you please downconvert your VI (File->Save for previous) and attach again?
I prefer LV2019…
Message 8 of 23
(1,641 Views)
 I have now saved it as 19.0 version which I think is for LV2019. Please Let me know if this is not correct
Message 9 of 23
(1,637 Views)
Hi AJ,
thanks for conversion.
Suggestion:
You don't need additional indicators for gauges: enable/show their digital display!
Place a wait inside loops waiting for user actions…
Place constant code outside of loops…
I used a simple chart to display your data. Try for yourself…
Message 10 of 23
(1,620 Views)
