How to store data from channels into constants
Hi
I currently have a six channel data acquisition system for LVDTs. The way the process works is we do a calibration run on the LVDTs and store the values we get and then use these baseline values during actual measurement. My question is how do I acquire these values and store them in constants within the program itself ? I know we can write these values to an external excel file or text file but can we store them within the program so that I have them available even if I close and open the program again?
(2,846 Views)
You can only change the control default value in edit mode. If you need to change the default value you need to save to a file and set the values of the controls from that.
LabVIEW 2012
(2,845 Views)
Perhaps this will work for you.
(2,837 Views)
That's a good idea. Keep in mind that this will only work in the development environment.
LabVIEW 2012
(2,830 Views)
