How to store Real Time data obtained from analog input module to array (NI cRIO 9068)
I am using NI cRIO 9068 with NI 9242 module. I imported this analog input into LabVIEW. I want to store one cycle sampled data into an array.
Any suggestions.
Message 1 of 8
(3,798 Views)
Thanks for your suggestion.
By using this code one sample stored N times. I want to store one cycle samples.
Message 3 of 8
(3,765 Views)
I can't test now, but try my code.
Variable should wait new point each time you ask data
Message 4 of 8
(3,756 Views)
I tried by placing scan synchronisation block.
But now i got the samples. But the every cycle have different number of samples.
How can i get equal number of samples for each cycle.
I am using 50Hz sinusoidal voltage with 342V peak value. i am getting that signal from NI 9242 Module using NI cRIO9068.
Message 5 of 8
(3,714 Views)
Can you share your latest code so we know what you have?
Message 6 of 8
(3,705 Views)
thanks for replying
In the image, I write down what result I am getting.
Message 7 of 8
(3,692 Views)
thanks for replying
Message 8 of 8
(3,692 Views)
